Drivers door is detached???
Old 03-19-2013, 01:50 PM
2000Hawk#317's Avatar
Default Drivers door is detached???
Had the window down and went to opened the door and it made the loudest pop sound I have ever heard from a door.
What happened, is that the door on the front half under the mirror, had come un-glued and with the window down, caused the exterior door panel to bow out slightly. When I tried to open it, it cought on the front quarter panel. There is no paint there anymore.
What compuind/adhesive should I use to get this to stick?
Attached Thumbnails Drivers door is detached???-img_0894.jpg   Drivers door is detached???-img_0895.jpg
Old 03-19-2013, 02:24 PM
MM98's Avatar
3M panel bond, part # 08115 & the manual applicator # 08117.. Might be best to pull the door so you can get the surface really clean & clamp the skin down til the adhesive can cure.
Old 03-19-2013, 05:24 PM
3gensoffs's Avatar
^^^^ what he said. seems like this may be a common issue. i saw a post on the same issue a while back. anyone else had this problem?
Old 03-19-2013, 07:48 PM
Thanks. I did pry on it a little with a flat head to show these pictures. Can still open and close the door. But want to fix it before it's sitting on the road or something crazy... Thanks again
Old 03-19-2013, 08:13 PM
PrplTA01's Avatar
I have seen this a couple times as well.. The 3M panel bond will fix you right up!
Old 03-19-2013, 08:21 PM
chromeplated500's Avatar
I did this a few years ago to another car I had, i was a little blown away at first. Had a body shop squirt glue in and sent me home!
Old 03-19-2013, 08:33 PM
I just bought the car too. Luckly found it in front of the dude I got it from. He didnt know about it so we took care of it. I've never seen this before so I figured someone would know the right combo to make it work. It was just crazy when we first saw it. Thanks again
Quick Reply: Drivers door is detached???
