Driving to tuner after gear swap?
I swapped rear ends and went from a 2.73 gear to a 3.42 gear in an A4 car. I have to get the car about 20 miles to the tuner. I'm wondering if its going to be possible to drive the car there, if i shift manually, without a lot of crazy downshifting going on.
The shift points will be off because the speedo is off. You can drive it wherever you want I just wouldn't beat on it.
The computer needs to see the desired shift rpm and mph before it will shift.
