Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Ls7
Old 03-23-2013, 10:30 PM
denscor's Avatar
Default Ls7
Category: Engine - Complete Motors
Price: $7000
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): WV
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
I'm selling my LS7 long block that is in my 2001 Corvette. The motor was built by Texas Speed and Performance . Its a wet sump motor,the block was done by Texas Speed and Performance.I have the build sheet if anyone is interested. I would like to get 7000 out of it, which is a great deal. email if interested.
I still have this motor .Here Is a the build sheet
GM LS7 bare engine block
Eagle LS1 4.00 Stroker Crankshaft
Eagle LS1 6.125 H-Beam Connecting Rod Set with Upgraded ARP 2000 Rod bolts, 2.10 crank journal,
.927 Wrist pin
Texas Speed exclusive LS7 Flat-top piston set 4.127 bore,4.000" stroke , 6.125" rod length, -3.8
valve reliefs for LS7 cylinder heads, with wrist pins
Diamond racing plasma moly ring set with upgraded hd steel top ring, 4.125 finished bore 1.5/1.5/3.0mm ring set
camshaft bearing set for ls2 and 2nd gen ls1 engine block
Clevite H rod bearing
Clevite H main bearing set
Precision Race Components CNC Ported LS7 Heads with hollow-stem intake valves and PRC 1.290"
Diameter Dual Valve spring kit with Titanium retainers
Texas Speed and Performance Custom grind LS1 Camshaft 232/240 .609/.623 115 LSA
GM cadillac lifters
TSP modified LS6 Oil Pump
The compression is 11.4 with .051 head gasket.The miles on the motor is around 600-700 miles.If someone was interested I could add the intake for a little more.
Old 03-24-2013, 06:16 AM
Mike08ss/tc's Avatar
Old 03-24-2013, 06:54 AM
Baconz28's Avatar
If you don't mind me asking what's the reason you selling the engine? Anything wrong with it?
Old 03-24-2013, 07:37 AM
70 gsconvt's Avatar
Is the intake a stock LS7? What about injectors, fuel rails, any wiring, front accessories, engine covers? The engine is setup up for a manual trans, correct?
Where in WV are you located? I'm not far, so hopefully in the northern area? Any dyno time or hp/tq numbers? Seems like the specs on that cam it would make another 20-30 hp.
Quick Reply: Ls7
