TrickFlow Injectors
Old 03-25-2013, 08:44 AM
neal1980's Avatar
Default TrickFlow Injectors
Hi,
Im building a 383 Turbo motor at the moment and need some injectors. Im building the engine to run 800+bhp pump fuel 98RON UK.
I have a Fast inlet, 102 and FAST Fuel Rails.
The injectors I am looking at are on summit TFS-89095 TrickFlow 95lbs for $450.00.
I will be running at 3bar Fuel pressure with a return system.
Does anyone know if these will fit my FAST setup or is there a better injector for my needs?? I have seen talk of adapters for the injectors and I dont want to run these.
Thanks
Neal
Old 03-25-2013, 11:57 AM
EricYJ-TA's Avatar
You will need the skinny - shorter LS2 type injectors. The fat ones will not work due to the body of the injector being too big. Also LS1 type injectors will work as well but you will need the correct rails and adapters.
Old 03-27-2013, 05:22 AM
neal1980's Avatar
Thanks for the reply.
So thinking now about Siemens Deka Injectors 80lb, these seem to be skinny type. Would these suit my needs?? Look very well priced as well at £400 for 8
Old 04-01-2013, 04:53 PM
stevieturbo's Avatar
http://forums.corvetteforum.com/c5-f...s-on-sale.html
Although the 80's should do you
Quick Reply: TrickFlow Injectors
