efi live help
Old 03-25-2013, 01:26 PM
nicentech's Avatar
Default efi live help
Can efi live v-2 data log two wideband inputs? I know it can log one thru the serial port, can two be configured to log thru the serial port? Ive searched around and couldnt find much other than a cable kit from ta that is no longer available. wouldnt readings be different if one was logged analog and the other via serial?
Old 03-25-2013, 04:11 PM
wait4me's Avatar
you can use any input you want for anything, you could use the 0 to 5 volt inputs for anything you want and at any time. The serial port can be used as well. You would just select what channel you want in the scan tool in the external section. The lm2 has 2 widebands in one if you buy it that way.
Old 03-27-2013, 03:55 PM
joecar's Avatar
FSV2 can simulataneously log 2 same-brand widebands thru the serial comms port.
If the serial comms cable is not available it can easily be made.
Old 03-27-2013, 08:02 PM
minytrker's Avatar
That's the best setup right there!
Quick Reply: efi live help
