Mustang Swap T56 guys/ T5
Old 03-26-2013, 05:59 PM
Jimbo4259's Avatar
Default Mustang Swap T56 guys/ T5
Im collecting parts for my LS motor swap in my 88 Mustang GT.
Im going to get a pullout t56 from an F-Body Camaro & Im curious as to what else will I need from the car?
and for you guys using the ls1/t56 combo how does this shifter work for you guys? It seems a little flimsy to take any hard shifting.
Old 03-27-2013, 09:36 AM
johnyrrr's Avatar
who makes it got a link?
Old 03-27-2013, 03:55 PM
Jimbo4259's Avatar
It was a McLeod peice if im not mistaken but I couldnt find it on their site. So Im assuming that its discontinued (I'd double check though) but MGW make something simlar. link below.
http://www.mgwltd.com/camaro_short_throw_shifter.shtml
Old 03-27-2013, 04:13 PM
tired2valve's Avatar
hell my 99 mustang 5.3/t56 i had to cut the body back about 2in to get the dam thing to fit. are yall fox guys needing it to be that far back?
Old 03-27-2013, 06:30 PM
Jimbo4259's Avatar
(from what i read) where it comes through the floor is about the same (2 inches back) but in order to retain the stock shifter location we need to move the shifter handle forward about two inches. the shifter arm can be rotated 180 degrees to put the shifter in the correct location (or close to it)
Old 03-27-2013, 07:59 PM
Oh ok I had cut my floor back about 2inch so the Trans sit flush. Then made a custom shifter with the height that suited my style/highth
Quick Reply: Mustang Swap T56 guys/ T5
