NANO questions
NANO questions
I am trying to figure out which port on the nitrous bottle the NANO fee line connects to on the nitrous bottle. I've seen it installed in both the 1/8NPT gauge port and the blow down port. Which one is it?
Also, if it is installed in the gauge port, wouldn't the 3000psi NANO burst the blow down disk?
If there is a nitrous pressure gauge installed on the bottle, does it get thrown off by the 3000psi NANO or does it read the N2O pressure correctly?
Ls1tech & Truck Sponsor
You bottle valve will need to have a port that is common with the bottle itself, most gauge ports are common with the siphon tube to reed the pressure right before the feed line. You wouldn't want to use that because the nano would be trying to push air into the feed line, instead of just pressurizing the bottle.
The NANO setup is regulated done to 1000 psi so you wont have to worry about the burst disc. It also wont affect the the gauge reading.
Trey
Trey
