Cam sensor question
Cam sensor question
I just installed a 231/237 cam Started the car runs fine had the tuner come to my house and start tuning everything good cars runs and drives fine (7 times around the block)But when he hooed his scanner up.It showed no cam in the car how does one tell if it went bad or what causes them to go bad?Everything is tightened to spec and lock tighted Got a new one on its way from gm suposed to be here tomorrow.hoping this should fix anything I should look for?
