Comp Magnum Rockers 1.75 and Low mile LS7 Clutch
Category: Drivetrain
Price: $300
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): AL
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
First up is a Set of Comp Magnum rockers with around 10K miles.
LS1/LS6/LS2 not 100% sure if it will work with LS3/LS7
COMP Cams
Pro Magnum Roller Rocker Arm Upgrade Kit
COMP Cams Pro Magnum roller rocker arms combine the strength of 8650 chromemoly steel and the weight savings of aluminum rockers. COMP Cams took advantage of computer design to simulate the stresses that affect rockers under various operating loads. This allowed the engineers to lessen the rockers' mass at non-critical areas, and strengthen the areas that take the most punishment. The results were rocker arms that are strong where they need to be, and actually weigh 5 percent less at the valve than comparable aluminum rockers.
INCLUDES:
1.75 Pro-Magnum Rocker arms x16
5/16 Flat Guide plates for 5/16 pushrods x8
3/8 Rocker Studs x16
3/8 adjusting nut x16
Set screw for 4654 x16
New $500
SOLD!!!
Used LS7 clutch kit (Pressure Plate, Clutch disk, and Flywheel.
Less than 10K miles. Drives great. Replaced with Higher HP clutch since I was rebuilding trans and adding supercharger and didn't want to ruin this one. Drives fantastic. Never seen the track or sticky tires.
New lowest I could find was $420 plus shipping . SOLD!!
Please Email Pzeller12@gmail.com
Thanks all!
