Standalone oil system
I am doing a standalone oil system for my rear mount TT build on a C5 vette. wanted to run my setup by anyone with experience to see if I am missing anything. I will have a tank mounted in the rear compartment. 5-6qt. then a pump to a small oil cooler with fan. from that it will run a T to each turbo. then return line will have a t fitting to a pump back to the tank. I am using an6 lines 1/4npt 3/8 hose. I have been reading up on check valves and will be installing 1- 2 on pressure side before the turbo. somewhere in the mix I will have a pressure and temp gauge installed.
