Routing Steam Tube To Water Pump??
I ordered a Griffin radiator and it only has 1 barb coming off of it to go the the overflow tank. My question is can I run the steam tube (the one from the back of the heads) to the top left heater hose spot (no heater anymore) or does it have to go to the rad?
I'm pulling my water pump off this week and will be pulling out the hose ends and plugging them with pipe plugs after I tap the pump. If I can plumb the steam tube to the pump it would be so much easier and cleaner than running it to the rad.
Thanks in advance
Thanks in advance
It would probably be ok, IMHO. That is the heater outlet port (coolant coming back from the heater core). It would be better if you used the return hose to the radiator, though. The 94 hose already has a tee (#14) in it for the steam line.
