Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Preferred fluid for slave cylinder?
Old 04-19-2013, 04:42 PM
citationtech's Avatar
Default Preferred fluid for slave cylinder?
I checked the fluid level in my clutch reservoir and found some dirty looking blue stuff. I have to assume it's ATE's "Super Blue" DOT 4. I've read about the importance of bleeding/flushing the V1 slave on a regular basis so I'm wondering if you guys have found a type that works best. I've use Valvoline synthetic DOT3/4 in my 340whp GTI equipped with a Southbend stg 3 clutch, seems to work well..
Old 04-19-2013, 04:49 PM
CTS-V Shifter Sales
07CTS-V's Avatar
The concentric slave cylinder inside the bell housing sees a lot more heat than your gti's. I use Castrol SRF. It lasts 4-5 times longer than Motul RBF600 does for me.
Old 04-20-2013, 03:36 AM
pearsonmx6's Avatar
Srf is what I was comming in here to say. Its what we used when I worked for bondurant and held up very well.
Quick Reply: Preferred fluid for slave cylinder?
