anyone with a quicktime, is ur clutch noisier?
Just installed a monster stage 1 race clutch.......new pilot busing.......I also put in a QuickTime and tick master as well.......the GM.slave has roughly 3000 on it.........with the car in the air and clutch in, it makes a noise very similar to when u push in the clutch on a tractor trailer, but with more metal on metal noise.......nothings clunking or intermittent just sounds like slave noise......did anyone else experience lots of noise after a bell housing install? QThere are a ton of inspection holes in the bell so maybe the noise is normal u just never hear it with an alum. Bell
Talked to snl and say that there shouldn't be noise.....just confusing y everything is normal........still just seeing if anyone's bell is causing things to be louder......saw on the instructions of the bell about checking some kind of tolerance with a special tool.....that wasn't done.....could that be my issue?
