1994 Trans Am T Top built for LS1>> PARTOUT<<
Category: Accessories
Price: $1234
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): MO
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Full charcoal leather interior
6spd console no upper boot
6spd pedals
Battery relocation box to the rear with battery disconnect switch and all wires
Big block functional ram air hood
Formula rear fascia
Raised wing hatch with 5% tint
Eibach prokit lowering springs mounted on newer 02 ss struts with brand new strut mounts and newer 02 ss shocks
Founders Performance adjustable panhard bar (red)
LS1 UMI street version tubular k member (black)
02 ss spindles
02 ss front calipers
02 ss rack n pinion
02 ss steering joint
Brand new ball joints, upper and lower tie rods
Drilled and slotted rotors on all four corners, fronts ls rears lt
LS1 Dynatech 1 3/4" stepped to 1 7/8" long tube headers with black 2000degree heat coating
LS1 radiator
Radiator overflow tank
Stock LS1 cam, timing chain, pushrods, and springs
If i havent listed it and it is normally found on a car I probably have it. I DO NOT have any AC components though. I will post as parts are sold. I am removing engine trans comp harness from car Monday, tear down begins then and can have things available asap.
BEST offer on parts get it. PM me and I will get to you quick as I can. May be able to ship most parts at buyers cost, some things I may not ship though.
Thanks for looking, chris
