Does anybody make a timing and progressive controller in one?
Old 04-21-2013, 03:42 PM
second_2_none's Avatar
Default Does anybody make a timing and progressive controller in one?
Does anybody make a timing controller and a progressive all in one? If not what is the best timing controller and progressive controller that are the most affordable? I use to see something called a "Timing Tuner and Nitrous Controller" that would allow you to pull timing, has a window switch, and has a nitrous delay. Does anybody still sell that or anything like that. I'm looking for a way to pull timing and a progressive, or at least a delay for the nitrous.
Old 04-21-2013, 04:52 PM
HCI2000SS's Avatar
I run one of these...check this out, and see if it's something you might like
http://www.lingenfelter.com/mm5/merc...3#.UXRfMXYRj5A
Old 04-21-2013, 05:07 PM
That does look like a nice piece, but it doesnt offer a nitrous activation delay or progressive controller.
Old 04-22-2013, 09:49 AM
brandon@nitrousoutlet's Avatar
LNC-2000 and an NOS Mini 2-Stage Progressive Controller is what I would suggest. Unfortunately there isn't currently an all-in-one unit for this.
Old 04-22-2013, 05:10 PM
LS1Tech Sponsor
Jason Haines @ LPE's Avatar
Default Progressive nitrous controller and timing retard
We don't make a nitrous controller and a timing retard controller in one unit but our progressive nitrous controller is able to communicate with our timing retard controller, allowing you to do progressive nitrous control tied to progressive timing retard control.
Here are links to the two products:
Old 04-22-2013, 06:00 PM
Sounds interesting, I'll check them out. Thanks!
Quick Reply: Does anybody make a timing and progressive controller in one?
