Prostars on TRANS AM!!!
Old 04-23-2013, 04:16 PM
thailam5's Avatar
Default Prostars on TRANS AM!!!
So, I am thinking about putting weld prostar wheels. Just getting an idea of what size for the wheel and tire and offset. I do work at discount tire... but we do not distribute weld wheels. Anyone have pictures with size specs, and tires your running? Thanks!!
Old 04-23-2013, 04:29 PM
Raven02TA's Avatar
15x10's 7.5" back spacing. running 325/50R15 28" tall....
Old 04-24-2013, 08:21 AM
Brutal Boba Fett's Avatar
Raven02TA, damn that is alot of rubber, looks pretty brutal though.
Old 04-24-2013, 10:22 AM
k_garretson23's Avatar
these are my buddies prostars on my car. the rear are 15x8 7.5bs. with hoosier 26"x10.5" slicks. the fronts im not sure about im pretty sure the width is 3.5". I just bought new rears 15x5.5 bs and right now theyre getting 27" hoosier qtps mounted on them Ill get a pic when i pick them up.
Old 04-24-2013, 04:07 PM
Raven02TA's Avatar
the 5.5" bs will stick out past the 1/4 panel, thats the mustang size bs. be sure your shocks are stiff.... you might hit the 1/4 on a launch and dent/wrinkle it, from your pic you look like our will be alright....but i learned it the hard way.
Old 04-24-2013, 07:29 PM
I test fitted then with out any issue. The sticker said 5.5 back space but i don't believe it.
Quick Reply: Prostars on TRANS AM!!!
