LS1 intake bolt question
doing the ls6 intake and pcv conversion and when i took our intake bolts out they had some black carbon on the threads and the passenger side front was a little worse then the rest. do I use sealer on the bolts when i put them back in, they had no oil up high on them just at the thread area.
I am no expert but I just reinstalled my intake a couple weeks ago. I did not put anything on the bolts. Make sure to use the correct torquing sequence and you should be fine. Final torque is 89 inch pounds. Like I said, I am no expert. Maybe try posting something in another section on this forum and you will get more info.
