Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Best options for fuel pump(s)
Old 04-27-2013, 10:46 AM
B_ROCKS_IT's Avatar
Default Best options for fuel pump(s)
Okay so I found a few threads on this, but they were older, wanted to see if anyone feels like they have the best solution; I need to get a second pump (likely WB400) running off hobswitch above 6psi. DO I need to do surge tank or can I make it work intank etc...
Thanks
Here are threads I was looking at:
https://ls1tech.com/forums/cadillac-...uel-pumps.html
https://ls1tech.com/forums/cadillac-...ank-pumps.html
Old 04-27-2013, 10:51 AM
FuzzyLog1c's Avatar
LS1Tech 10 Year
And now begins the $1000+ adventure...
Old 04-27-2013, 10:55 AM
B_ROCKS_IT's Avatar
Cmon dont say that... I am about to drop 5+ on clutch and 8.8
Old 04-27-2013, 11:07 AM
DMM
DMM's Avatar
Welcome to the club!
Old 04-27-2013, 11:16 AM
B_ROCKS_IT's Avatar
- I should have a copy of my tune for you to look over today...
Old 04-27-2013, 12:17 PM
FuzzyLog1c's Avatar
LS1Tech 10 Year
One thing that might help you cheaply mitigate those fuel pressure transients is larger diameter fuel tubing and better filtration.
Did you see the -8AN parts that I posted up earlier? Summit Racing sells 100 micron pre-pump, 10 micron post-pump, and a 20 foot stainless steel hose kit.
While it won't solve the problem in and of itself, the additional volume carried in the lines will slightly reduce the severity of the initial surge.
Old 04-27-2013, 01:21 PM
Skidmarcx's Avatar
You may as well do a fuel cell at this point
Old 04-27-2013, 01:41 PM
vmapper's Avatar
Just wondering how you are obtaining 770+ rwhp and you are now inquiring about fueling?
what do you currently have for a setup?
Old 04-27-2013, 02:35 PM
FuzzyLog1c's Avatar
LS1Tech 10 Year
Probably because he went to get his car tuned with 114 octane in the tank.
Old 04-27-2013, 08:28 PM
B_ROCKS_IT's Avatar
Yep fuzzy said it, I'm running a walbro 400 and 70# injectors... Ran 110 on the dyno day - just did another dyno today with 110 on a dynopro and got 725 on 12psi...
So after speaking with many people at the dyno, my builder and 98Cobra from on here, it sounds like the most cost efficient way to run dual pumps will be to bulkhead the second wb400 off the passenger side of tank, run new line up to passenger fuel rail, and run the whole second pump off of hobs switch.
I will need new injectors also though, any one wants my 70's let me know.
Old 04-27-2013, 08:32 PM
FuzzyLog1c's Avatar
LS1Tech 10 Year
Buy ID850s and be done with it.
Old 04-28-2013, 12:10 AM
vmapper's Avatar
You bet! and the best part is you get all the data to run these...
Old 04-28-2013, 12:21 AM
vmapper's Avatar
As for most efficient way, I can not suggest anything.. the route I took was an extreme pita...
Bought two buckets, put one on each side (drivers and passenger) with plenty of pump to cover 1000+, using a X pattern for the pump jets, using 1/2" I.D. 100% Fluoroelastomer tubing.
Ran twin -6 feed lines to the FST performance fuel filter block then -8 to the front rail, then through an adjustable regulator and -6 return back to a Y then -6 return to each return (5/16" - reducer)...
yea, lots of line, lots of tinkering... but I wont have to worry about gunning it on a low tank...
You could probably get away with what you already have in mind...
Old 04-28-2013, 09:45 PM
itsslow98's Avatar
Buy ID1000s and be done with it.
Fixed
Old 04-28-2013, 10:08 PM
ColeGraham's Avatar
ID850s $900 new...ID1000s $950 new...
Like itsslow98 "fixed"...get the 1000s...850s start running high on their duty cycle at 700+.
Old 04-29-2013, 01:29 AM
runsfromdacops's Avatar
just get the FIC1150s so you have room for e85.i have them in my car and i love them and they are cheaper then the ids
as for the fuel pumps
if i still had the stock tank in my car i would have gone to a small surge tank in the trunk.
for pumps id go with 2 bosh o44s or 2 wd400.
Old 04-29-2013, 07:45 PM
vmapper's Avatar
Originally Posted by runsfromdacops
just get the FIC1150s so you have room for e85..
This is a good point.
I always forget about E85, its not available anywhere near here.
Old 04-29-2013, 10:23 PM
s-cam's Avatar
I did exactly above- small surge tank, 2 bosch 044s ( surge tank mounted outside of truck behind rear passenger wheel) -8 feed, -6 return, aeromotive regulator etc.
Old 05-02-2013, 11:14 AM
B_ROCKS_IT's Avatar
Thanks for all the help guys!
Old 09-29-2017, 08:08 PM
rcotillier's Avatar
I know this thread is old, but vmapper how reliable was the dual fuel pump bucket adn do you have a write up on ow you did it?
Quick Reply: Best options for fuel pump(s)
