Intercooler questions
Old 04-29-2013, 05:51 AM
simplysix's Avatar
Default Intercooler questions
So I'm installing my front front t72 this weekend. I'll be running a tial wg with a 5.8# spring. At that boost level, how important is an intercooler? Will it just make a little more hp, or will it help the motor handle the boost due to lower iats?
I do plan on getting a nice intercooler cooler set up later, but would rather not do it now unless 100% necessary. Thoughts?
Old 04-29-2013, 07:31 AM
Blackpanther99's Avatar
If your gonna push over 10PSI then I would run one to reduce the charge-air temperatures. Any where between 5-9 PSI you should be good with no intercooler but I would still start to invest in one.
Old 04-29-2013, 08:33 AM
stevieturbo's Avatar
At only 6psi I really wouldnt worry unless you're in a very very hot climate.
Old 04-29-2013, 10:33 AM
simplysix's Avatar
Seems like its not necessary is the general opinion. That's kinda what I figured, thanks guys
Old 04-29-2013, 07:42 PM
No problem. Be safe.
Old 04-29-2013, 10:26 PM
itsslow98's Avatar
Anytime you can lower IATs the better off you will be. Is it absolutely necessary, no....but will it help....most definetly.
Quick Reply: Intercooler questions
