anyone had this code thrown? p0102
have 98 ls1 in 69 camaro throwing code p0102 says low input mass airflow. want to see if anyone has had this issue , i figure its bad mass air possibly?
had it last week in my 98 z28 with ls1, shot the wires to the MAF and got incorrect readings. thought i had a broke wire but if you are running the ls1 wiring and fuse box, there is a 20amp fuse labeled Engine Sensors and its actullay your MAF fuse mine was blown. threw in new fuse and code went away. also if you have the ls1 wiring i know what wires you need to check to find out if its MAF, wiring or fuse
