Adding boost gauge to brake booster hose
Old 05-01-2013, 06:29 AM
ramairetransam's Avatar
Default Adding boost gauge to brake booster hose
I want to add a t fitting to my brake booster line to add my boost gauge . i cant find a 3/4" to 3/4" with a 1/4 out on it . I found a 3/4 by 3/4 with a 3/8 out but that's the closest . How else should i plumb this in or where should i put it .
Old 05-01-2013, 08:33 AM
Mereniuk's Avatar
1/2 t fitting, to a vacuum block, then use one of the ports on the block. That's all I did, also my Bov, waste gate, gauge, is on the block as well. That's what I was told to do.. Haha
Old 05-01-2013, 08:35 AM
1/2 t fitting , i think its 3/4" and i only need the one outlet on it .
Old 05-01-2013, 12:22 PM
Ferocity02's Avatar
I used a 1/2 x 1/2 x 3/8 T fitting for the brake booster, it was too small but the hose clamps made it work. I think it's more like 5/8".
Quick Reply: Adding boost gauge to brake booster hose
