T56 can't select second even engine off
Hi I have a gto spec t56 ( was built by 6 speed inc) it's always been very nice change and no problems but it's behind a ls3(7.0l) twin turbo motor in a rx7 I've had problems selecting second and first mainly when hot , I thought it was the twin plate clutch but I've fitted a new clutch and all seemed ok till it got hot and first to second got very stiff and had to pull hard to get it out off gear . Not even cold I can't get second at all feels like there is something in the way and grinds if you try to push harder , all the other gears are fine with no noise it has a rip shifter fitted which seems fine any ideas ??? I'm in England and not much help over here with these boxes
