please help with tunerpro
i spent all day trying to get tunerpro to work. so effin mad i cant see straight.
car is a 94 auto z28
i have the latest tuner pro rt
i have the adx files and the xdf files.
cable driver are installed and working
i get the da not connected 90 percent of the time, the other 10 -
it says da error. and it glitches.
im using the night dash adx file that someone here uploaded.
i tried 2 different computer with the same outcome.
last night i as able to data logg for 4 mins -- no problems.( this was a one time thing) -- but the last 8 hours spent with today .... nothing.
i have changed the latency for the com port. that did nothing all day
i pulled all fuses for abs module...
what else am i missing...-- one last attempt on here before i give up
https://ls1tech.com/forums/lt1-lt4-m...-tutorial.html
try that ... if it wont work and you have checked that you have the right adx/xdf files, then there is prolly somethin wrong with the wiring between the computer and the aldl connector
