AIR system exhaust plug
Old 05-05-2013, 01:37 PM
jrwilliams95z28's Avatar
Default AIR system exhaust plug
Hi I am trying to removal my ac and air system, what can I use to plug the threaded female holes in the factory stock exhaust manifolds? I heard since my car is a 1995 that it has a 22mm head, would a o2 bung plug work?? I think they are 22mm. Thanks!
Old 05-05-2013, 10:12 PM
05_quick4door's Avatar
I used a carriage bolt with the threads cut off with the factory threaded part smashing it yeeeeaaaars ago. Worked great
Old 05-06-2013, 05:07 AM
RamAir95TA's Avatar
Either an M18 or M22 drain plug will work fine. They are common enough where you shouldn't have to rig it.
Old 05-06-2013, 06:59 AM
thanks! I called napa they have them! appreciate it!
Old 05-08-2013, 07:46 AM
pinecone_27's Avatar
Perfect fit worked great thanks
Old 05-12-2013, 05:55 PM
Bucksnbass's Avatar
the m22 is what I used and fit well also
Quick Reply: AIR system exhaust plug
