Procharged ls1 pcv help
Old 05-06-2013, 08:20 AM
tranb000's Avatar
Default Procharged ls1 pcv help
Would it be okay to run a line from the driver side valve cover over to t into the back of the passenger side port, then run up to the pcv valve, then to a catch can to a one way check valve to the intake. I've seen where they say to block off the passenger side port but didn't know if it would hurt to have it t'd like from factory or why you would want the passenger side rear port blocked off. The the front port of the passenger side valve cover will be ran to the inlet of the procharger.
Quick Reply: Procharged ls1 pcv help
