a rock fell in my injector hole
Old 05-06-2013, 04:17 PM
jhobbins's Avatar
Default a rock fell in my injector hole
How can I get this out? I thought I cleaned off the area enough before I pulled the fuel rail but there was a small rock hiding between the injector and the intake. When I pulled the fuel rail off it fell into the #8 cylinder hole
Old 05-06-2013, 04:31 PM
Tramminc's Avatar
Remove the spark plug, tape a small hose on an wet and dry vacumme and try to suck it back out the injector hole. Clean the vac first so you could inspect it.
Old 05-06-2013, 08:39 PM
fex77k's Avatar
Home Depot has a pretty good snake cam you can always test drive it.
Quick Reply: a rock fell in my injector hole
