nitrous on stock 5.3
Old 05-07-2013, 11:21 PM
ckeeney's Avatar
Default nitrous on stock 5.3
Will it hurt to not pull timing on a stock 5.3 and spray a 100 shot on it with stock plugs its on a 2013 silverado
ckeeney is offline
Old 05-08-2013, 09:16 AM
garygnu's Avatar
I would pull 2-3 degrees out ,and run good premium unleaded gas .I would not rely on the knock sensors to do the right safe thing.
garygnu is offline
Old 05-10-2013, 01:52 PM
2000PewterT/A's Avatar
Need to pull some timing to be safe, I wouldn't want to risk it.
2000PewterT/A is offline
Old 05-16-2013, 02:44 PM
SPDKNGG's Avatar
I would run some race fuel as a precautionary measure..you will be less likely to detonate.
SPDKNGG is offline
Old 05-16-2013, 04:04 PM
JDEP162's Avatar
Totaly no expert, in fact i havent sprayed my new system yet, but all the research ive done says do it right the first time. Safety equipment, window switch, wot switch, plugs, pull timing is a must.
JDEP162 is offline
Quick Reply: nitrous on stock 5.3
