Minimum safe distance for steel fuel line near exhaust pipe?
Old 05-09-2013, 12:54 PM
wrd1972's Avatar
Default Minimum safe distance for steel fuel line near exhaust pipe?
My steel fuel lines come rather close to my TD exhaust and I am trying to determine what the minimum safe distance should be. I have the fuel feed and the return lines wrapped in heat sock and they are a tad over an inch from the pipe right under the driver seat.
Thoughts???
Old 05-09-2013, 01:15 PM
Gojira94's Avatar
I've often wondered the same. On one of my LT1 cars, I'm trying something called inswool ceramic fibre. 1" thick, it is used to line forges. A buddy of mine build a couple of forges and gave me some to wrap around my lines. up to 2300* on one side, near-ambient on the other.
Old 05-09-2013, 10:45 PM
robsquikz28's Avatar
buy some header wrap and put it around the exhaust where the fuel line is.
As for distance between the 2 it should be 1" min to allow for cooking. But exhaust dont get as hot as headers, but it can still make fuel lines bubble.
Quick Reply: Minimum safe distance for steel fuel line near exhaust pipe?
