some type of short? Please help
Hi every one
I picked up a 2000 z28 its in good shape but has some issues like to see if i can get pointed in the right direction
I had a problem with the radio and window cutting out I did the bcm solder mod it had worked for about 150 miles now
the other problem is the DLR (amber front lights) one has a mind of its own (passenger side) works when it wants to and the l right blinker some times stays on with out flashing? I swapped the bulb inspected the harness dont see any thing it all looks good? when its out it will turn on if i turn the lights on
the brake light does not come on when i pull up the E brake but does light up when i start the car so i know the bulb is good
clueless......
clueless......
hey man, i was a chevy tech for 12 years, now with benz so i cant get schematics but im 99% sure all of ur issues are all related to bcm. GM bcm's were total crap back then, i never had too many issues with Camaro bcm's but, you prob need a NEW bcm outa the box. turn signals and DRLs def run off bcm, dont remember if windows do. If your still havin problems, ill find out if p/windows do.
so there was/is some thing up with it
