Need Clutch Suggestions
I'm getting to the point where I need to start thinking about the clutch for my project, so I need some input/advice.
My project car is a BMW Z4 roadster. I am in the process of building a 383 using an LS6 block, LS2 heads, and a factory LS7 crank/rods/oiling system. The goal is around 500rwhp (+/-). For a transmission, I'm using the standard F-body T56.
The car is a daily driver/weekend play toy. The goals are to have a sporty, excellent handling vehicle that is enjoyable to drive to work, go on weekend cruises, etc. IF it ever gets raced, it would be short track road course racing. With these goals in mind, I'm looking for the lightest (within reason) clutch setup that is reliable and reasonably priced (not looking to spend $2K for some exotic piece here).
My "default" is the LS7 clutch with an aluminum flywheel. I have used this setup in the Z28 and Silverado projects I did, and both were very drivable. I'm interested in/considering a multi-clutch pack that uses a flex plate, but I have zero experience with these so I don't know how they would work in my application.
Anyone with advice/guidance/etc. would be really appreciated.
Thanks,
Chris
Thanks,
Chris
I would look into the McLeod RST or RXT "twin" disc clutches if you are putting in a "LS" motor. you can get a aluminum or steel FW.
Your HP goal will go through a "stock" clutch so if you stay single disc you will have to get a more aggressive disc material. Monster is popular brand. SPEC 3+ may be another choice.
IMHO having been through a few single disc clutches of various brands and friction material, including supposedly enhanced PP with more clamp force, I just put in a McLeod Street Twin and steel FW. If weight is a primary concern a AL FW and single disc clutch will be the lightest set up
In the past, I had heard the McLeod twin discs were hard to setup/temperamental on their setup. Is that true?
That's alot lighter than I figured it would be but it's about what I'm looking for.
An aluminum wheel should be fine though it's worth noting that the engine will respond differently with the reduced mass (you know this from your experience with other builds though). Additionally, what are you planning to make in terms of torque? This will provide me the ability to offer the best recommendation possible. Let me know and we can go from there. Thanks,
I have always been very happy with the performance of aluminum flywheels on LSx based engines. Even my 4300lb silverado with a 5.3/t56 (NA with an LS6 cam) was very enjoyable to drive every day with an LS7 clutch/Alum flywheel.
I look forward to hearing your input.
Not bad at all. In truth a Stage 1 would be good for use with 450lb.ft at the wheels. But, having a little more clutch, for future mods, is always a good idea. If you are using this on the street only then a Stage 2 would be fine. Though, I am partial to our Stage 2+(I've used it in my last 4 cars with great results).
I had a SPEC Stage 3 clutch years ago (near 10 years ago) and to put it frankly, I hated it (it would not disengage high/7000 RPM). I had installed a brand new LS6 slave and an adjustable master cylinder with the clutch, along with re-routing and wrapping the clutch line (to ensure it stayed cool). I pulled it for the LS7 clutch and the issue (not being able to disengage at high RPM) was gone. So I want to make sure I don't get a repeat of that experience.
Stage 2 uses a Kevlar facing on both sides of the disc whereas Stage 2+ has a hybrid disc that uses Kevlar on one side and our carbon-graphite-semi-metallic pucks on the other. Both will have the same pedal effort which is not excessive at all (within 10% of stock).
Without having seen the Stage 3 you reference it's hard to know the cause of your release issues. Lots of things can affect this (including hydraulic issues, a bent disc, an over machined flywheel, proper spacing relative to the slave or a plate related issue). We provide a measurement sheet that should help you insure that you are within the proper window of operation. Let me know if you have any further questions. Thanks!
What's the difference between the stage 2/2+ and stage 3?
I would assume any "twin" disc clutch assembly will weigh more than a single disc clutch. You can run a aluminum FW with either set up.
The single discs with "dual friction" surfaces like a 2+ or higher stages with non organic friction materials do hold better than organic disc material but can be prone to chatter.
I know McLeod offers both a organic disc and a ceramic disc in their RST or RXT twin clutches which can be used with a AL FW. I assume other companies also offer twin disc clutches for the LS platform. McLeod is the only one offering a LT platform twin disc clutch that I know of.
I believe the RST or RXT McLeod clutches use the stock LS FW which is available in both AL or Billet aftermarket
pic shows .022 felt tight and .020 was just right. each clutch disc when made is slightly diffrent in thickness so shims are used to raise the floater plate to within spec. The clutch assembly from Mcleod came pre-assembled with the right shims. The directions just have you confirm measurements and if there is a problem to call tech line before proceeding
