Ford injectors on LT!?
Old 05-14-2013, 07:17 PM
BLK93TA's Avatar
Default Ford injectors on LT!?
I've read Ford makes really good injectors. Which style fits our LTs? Opinions? I wanna run 30lb with my head/cam/rocker swap and I do know iIhave to have it tuned for them. Thanks!
Old 05-14-2013, 07:31 PM
9-Second Club
Ed Wright's Avatar
The same ones that fit an old 5.0 Mustang. And, Ford doesn't make them. They are Bosch.
Old 05-14-2013, 07:58 PM
BLK93TA's Avatar
Would you recommend a fuel pump upgrade at all? Cars got 123k on it I have no problems but never changed it
Old 05-14-2013, 08:11 PM
96z28_lt1's Avatar
what would you be upgrading to 30lb injectors for? if the car is stock i wouldn't even bother....
Old 05-14-2013, 08:14 PM
9-Second Club
Ed Wright's Avatar
We don't know how many times it has been run low on fuel (pump killer, never let it get below 1/4 tank) or how much dirty fuel has been through it. If you just have a head & cam car it may be OK. If I was going to change it I would put a new GM pump back in it. Your probably OK. If fuel pressure doesn't fall off at high RPM, your OK. My 383" ran nines over 135 MPH on a 120,000 mile pump, all stock fuel lines and regulator. A lot of that stuff gets bought for zero gain.
Good luck.
Old 05-14-2013, 08:33 PM
BLK93TA's Avatar
Well the 93 came with 22lb injectors so mine are small. I'm putting a pretty large cam in it plus big heads and 1.6 roller rockers so I'm gonna be moving a lot more air. I can't stick with my 22lb for this set up. I could go to 24 but not much of a difference. I'vetalked to a few people about it said 30lb would be good wwon't be too high duty cycle or whatever
Old 05-14-2013, 08:51 PM
9-Second Club
Ed Wright's Avatar
You were told correctly.
Quick Reply: Ford injectors on LT!?
