Anyone here spray matte single stage and or matte clear?
I've been toying with a lot of SEM hot rod black lately and I was wondering if anyone else shoots a lot of matte colors. Whether it be matte single stage or matte clear.
I haven't had much luck getting different batches to dry with the same level of glossiness (or lack thereof should I say).
Not too big of a deal when doing small batches that don't get seen together. But I'm trying to put a finger on what factors play into the gloss factor.
I have not played with any matte clear so this more applys to single stage, but I'm all ears for any insight.
I have a feeling the major factor is how wet of a coat is sprayed, humidity being the second major factor.
I've seen these different gloss levels with both the SEM 2k paint and some cheap lacquer matte paint. Hell one time I tryed spraying summit brand "hot rod black" and it came out glossy as glossy could get! I'm not sure if I got a mislabeled can or what, because I set that stuff aside and never used it again.
Soooo any painters in here have any ideas?
I would get a sheet and see what the specs are for amount of coats and dry times ect... its been a while since I have sprayed the SEM matte. but I spray a single stage at work that when mixed 5-1 its full gloss. when you mix it 6-1 its a semi gloss. so see what the sheet says and just follow it exactly. I would say its different amounts of catalists that is causing the variance for you...
I guess Im going to have to bight the bullet, buy a kit/ some extra catalyst and play with it myself if no one's got any general ideas.
I suppose I could call SEM, but as of late every time I get a hold of large companys tech support, 9 times out of 10 I get some drone that doesn't know his *** from his face. I've just kinda gave up trying to get info direct from companies in most instances, but I guess it couldn't hurt to try.
Shake or stir thoroughly. Mix by volume: 4 : 1 : 1
HR014 HRC06 HRR06
NOTE: Use of additives other than HRC06 and HRR06 are not recommended and will affect both
the appearance and performance of HOT ROD BLACK.
1. Set air pressure to: 40-45 psi non-HVLP
8-10 psi at the cap for HVLP equipment
2. Use a gun equipped with a 1.3 - 1.4 nozzle.
3. Spray one medium-wet coat keeping the gun 5-7” from the substrate. Allow to flash dry, approximately
10-15 minutes.
4. Spray a second medium-wet coat and allow an additional 10-15 minutes before baking for 30 minutes
at 120°F, or air dry for approximately 16 hours.
NOTE: Always spray a test panel to ensure desired gloss level. Variations in temperature
and gun set up can affect the final gloss of HOT ROD BLACK.
sprayed 2 cars with SEM so far, both seem to have came out about the same. I'm not sure if you now of Keystone/LKQ but keystone has a kit for $50. I have some of it, seems about the same
