Will this Timing set fit??
Hope you guys can help.
I have a Comp timing set for an LS2. It is the 3158KT. It has the bumps on the cam sprocket for the LS2 cam sensor. My question is, will this timing set physically fit an LS1 engine? I know the LS1 doesn't use a front sensor, but is there any other reason it wouldn't work on an LS1?
Thanks in advance.
Jeremy
Thanks in advance.
Jeremy
