Non return fuel rail.
I built a model a roadster with an ls1, just bought a fuel rail off Craig's list off a 99 vette. The one with no return line. How does it regulate fuel pressure without a place to relieve to? Does it regulate pre- injectors?
Hey Lonnie. How does the stock LS-1 setup/rails regulate without a return line? Following your suggestion, where do you put the return line? Do you place the regulator on your fule line and the regulator itself has the return line to the tank rather than a return off the rail? Clearly i'm a rookie! Thanks
