Fuel Pump Connector Wiring - Already Searched
Old 05-20-2013, 08:29 AM
Adrenaline_Z's Avatar
Default Fuel Pump Connector Wiring - Already Searched
Hello All,
I'm having a hell of a time finding wiring diagrams for the fuel pump bulkhead
connector on C5 tank. It's a 4 pin, flat, yellow connector.
I've tried several different word combos in the search feature, but I'm ending
up with the square, gray connector, or something totally unrelated.
This is a clean, custom install, so I can't use any factory wire colours, or
harness to reference. What I need is the wire assignment for pins A, B, C, D
on the following item:
From the bit of reading I've done, this is what I've found (please confirm, or correct) :
A (Purple) - Fuel Sender Ground
B (Black) - Pump power ground
C (Red) - 12 Volts Pump power
D (Blue) - Sender signal
The last option is to remove the fuel tank, and pump...but that's such a pain in this setup.
Thank you for any links, tips, info for proper connection!
Quick Reply: Fuel Pump Connector Wiring - Already Searched
