cam swap
This should answer your question. This is direct from Lingenfelter's website.
The LS9 camshaft is a 3 bolt design and will use the Lingenfelter 3 bolt cam conversion kit if you are installing it in a single bolt application like the 2007 – 2010 LS2 or LS3. If you are installing it in an earlier LS1 or LS6 engine with the cam sensor at the back of the engine you will need a 2005 LS2 front cover, 2005 1x cam sprocket, camshaft extension harness, 2005 LS2 chain dampner
