Notices
WTB-Heads and many other parts for LQ4 build..243/799s
Old 05-23-2013, 11:35 AM
nickleahy23's Avatar
Default WTB-Heads and many other parts for LQ4 build..243/799s
Building a LQ4 for my RCSB. Need to get some decent heads for it. Let me know what you have. Looking for some 243/799s. If you have decent springs(was told some Brian Tooley Dual .660) in them thats a plus. Planning on running a decent sized cam, something in the 23x/23x-24x range.
Also looking for the parts to go along with a head and cam install.42 lb injectors, fuel pump (if i need to upgrade),throttle body, Ls2 timing chain, Ls7 lifters, Ls2 trays, comp trunion upgrade, pushrods, headgaskets, and anything else.
Doing a 4l80e swap so I need a decent converter, 3600+ I would imagine.
Let me know what you guys have or where you would suggest finding some of the parts. Thanks.
Old 05-23-2013, 12:21 PM
Brian Tooley Racing's Avatar
I've got some used 243/799's coming off a car this weekend that is upgrading to TFS As Cast heads. My Platinum springs are already installed and I can make you a deal on them.
I also have a new Comp Cams 235/243 113 on the shelf for $299. I also have 42 lb injectors, LS2 timing chain, LS7 lifters, LS2 trays, trunnion upgrade, pushrods, and head gaskets all in stock.
Quick Reply: WTB-Heads and many other parts for LQ4 build..243/799s
