AEM EMS guys anti-lag issues?
Was this feature removed for the 1.21 cal files? With the Alt Ignition Fixed checked, even if turn the "Alt. Function input" to "Switch is always on" in the switch drop down it does not activate in the parameter bars.
Also tried hooking it up to a ground switch #4 input and manually triggering it with the engine running.
No luck.
Switch #4 to ground will work to activate other functions however.
Any tricks to setting this up?
No luck.
