Plugs and Plug Wires for 02 Z28
Old 05-24-2013, 09:36 PM
yukonblu's Avatar
Default Plugs and Plug Wires for 02 Z28
Hey guys, getting my car tuned here in a few days and gonna upgrade my plugs and plug wires before i get it done. Can you guys recommend the plugs i should buy. Thanks
Old 05-24-2013, 10:27 PM
Latch's Avatar
If you've only got bolt-ons then TR55s are a good choice. As far as wires go I got a set of OEM LS6 wires, they're red whereas LS1 wires are black. Can't beat OEM for fitment, I've even got long tubes and they are no where near any of the primaries.
Old 05-24-2013, 11:22 PM
trans_am7935's Avatar
i like the MSD wires, they have bendable boots.
Old 05-24-2013, 11:30 PM
yukonblu's Avatar
What about for performance though? Thats what im looking for.
Old 05-25-2013, 12:08 AM
94Z28-MSTGKLR's Avatar
I use AcDelco Platinum plugs and MSD wires. They are great. I've run them for three years with all the mods that are in my sig.
Old 05-25-2013, 12:55 PM
dailydriver's Avatar
I use the NGK Iridium LASER (the longer lasting, thicker center electrode, NGK Iridiums which outlast the copper, V-Power TR55s 3+ to 1) with Moroso Ultra 40 sheathed wires, as I DO NOT love changing plugs out as often as most on here do.
It is a 5 hour, working BLIND (NO lift) 1000 rounds with a wolverine ordeal for me, so the less frequently I must do this, the better!
Old 05-25-2013, 02:35 PM
libertyforall1776's Avatar
These are the plugs I would go with next time on my '01 SS (or the Denso equivalent, which I have in my '02 RS), but for the price of free, I went with the TR55s, for obvious reasons.
These guys say some good things about Denso Iridium plugs:
http://www.camarohomepage.com/project/part1.htm
MSD wires on both my RS & SS Camaros...
Old 05-25-2013, 02:49 PM
Latch's Avatar
I highly doubt there's any measurable difference in performance between aftermarket and OEM wires.
Old 05-25-2013, 03:02 PM
AmarilloWS6's Avatar
I ran AC Delco Platinums in my ws6 and run TR55's in my c5 both with MSD wires and I felt no difference between the two. TSP has a TR55 and MSD wires package deal for pretty cheap. I'd just go for that honestly.
Old 05-25-2013, 05:11 PM
LilJayV10's Avatar
TR55's and MSD wires. If you are looking for a real high quality wire look at the granatelli's w/ the heat sleeves.
There are no performance gains between the MSD's and the granatelli wires. When I had my car dyno'd I did back to back runs with the different wires and saw no difference.
The granatelli's are nice because they have a lifetime warranty.
Old 05-25-2013, 10:09 PM
sjsingle1's Avatar
i put champion IRs in mine......then took em out and put in regular autolites........those wore out fast !!! cleaned the champions and put em back in !!!! run just fine
i have granetelli wires.....even with TSP headers i have no need for heat boots
Old 05-25-2013, 10:32 PM
1BAD98LS1's Avatar
What are your mods? That'll depend on the plugs you need...as far as wires that just depends on what you want to spend...ie looks, name brands etc, such a short wire not much gains to be had there.
Old 05-25-2013, 11:00 PM
JDEP162's Avatar
I just put on a set of msd wires, great quality and performance. Br7 plugs but im spraying.
Old 05-26-2013, 12:48 AM
The Guz's Avatar
I just installed a set of AC Delco Iridiums and a set of stock wires on my dad's 02. His car only has an intake an exhaust.
Old 05-26-2013, 06:45 AM
sabersaw30's Avatar
My car dont like the tr55 pops up top. Loves the tr6 with a smooth idle but i got a small cam in the motor also.Mostly depends on your tune i have a fairly aggresive tune.
Old 05-28-2013, 01:14 AM
ls1 1990 VN's Avatar
You wont do better than http://www.firecore50.com/
Old 05-28-2013, 01:54 AM
bane89's Avatar
Thumbs up
I use ngk tr55's (part#3951) and msd street fire (part#5572)... Haven't had any issue.
Old 05-28-2013, 02:42 PM
Yes, the Denso Iridium Powers are a slightly better performing/idling plug than the Laser Iridiums (maybe even than the NGK narrow electrode Iridiums as well), BUT they only last ~10K miles more than a set of inexpensive TR-55s.
Like I said, I HATE changing plugs on these cars, and will do ANYTHING to prolong/avoid this, including using the LONGEST lasting plug I can install (even if that means giving up a hair of performance to the others).
Quick Reply: Plugs and Plug Wires for 02 Z28
