Emusa wastegate not closing fully
I got a brand new 38mm wastegate, hooked it up as per information on this forum, and noticed that even at idle I have exhaust coming out of it. I took it back off and can see day light between the valve and the seat. I took the top off, and removed the springs. The valve itself moves freely, it just feels like it stops solid before completely sealing off at the bottom. Anyone else had this problem? Is this normal? If not, is this something I can fix, or should I contact them about it? Haven't been able to get into boost yet to test the functionality otherwise
