engine temp
LS1Tech Administrator
Received 1,492 Likes
The stock gauge is junk. It will read right about 210 for any actual temp between about 190 and 230.
If you mean actual coolant temps as seen on a scanner though, your stock t-stat is a 187°F unit, so actual coolant temps shouldn't drop below this once the engine is fully warm. Stock fan settings will allow engine temps to range as hot as between 217° to 235° at idle/low speeds depending on load and conditions.
The '98s are closer to reality, and also will register with movement for smaller changes in temp. But the actual temp they show is still not 100% accurate, as you have found. '99-'02 are even worse though.
