c5 z06 problems
c5 z06 problems
Ok so to start off, my cousin has a 2001 z06, cam heads and intake, has full exhaust. Ok so his block broke where the starter goes and I have been helping him getting it back up and running, so I got a starter bridge kit from secondsucksracing or something like that here local in houston. And today finally got the starter bolted back and cranking. But now its acting funny anot its not starting, on the dash it gives u engine reduce power, service abs, service handling system or something along those lines, but while he pumos the gas (it hasn't been started in quite awhile) with the key just turned the tb opens but as he goes to crank it it doesn't open anymore, same for the fuel pressure on the fuel rail, key on I hit the valve and it squirts and soon as he goes to crank it it stops. Wiring the car is kinda sketchy due to previous motor swap but it did run the way it sits before, so now I'm stumped and I think it has something to do with the ecm and or wiring, anyone have any ideas, thanks in advance
