Head Gasket Selection
I am trying to pick a head gasket for my 4.155 bore ls7. I am having trouble locating one. I saw clevite makes a 4.165 bore gasket but i cant find detail on compressed thickness. Any suggestions?
19170419
LSX 4.200 Bore MLS Head Gasket Kit
• Multi-layer steel gaskets for naturally aspirated and forced
induction applications
• .051" thick
• Includes 1 LH and 1 RH gasket
• For standard LS and LSX 6-bolt pattern blocks and heads
• For bores up to 4.200"
19170420
LSX 4.250 Bore MLS Head Gasket Kit
• Multi-layer steel gaskets for naturally aspirated applications
• .051" thick
• For bores up to 4.250"
• .051" thick
19170420
• .051" thick
so it was recommended that I run the factory ls7 head gasket for this application by a very repitable source... just feel odd using a 4.150 gasket for a 4.155 bore. Any one ever done anything like this before?
this is a recommendation from whom some would consider "the best". Was just currious if anyone had ran a gasket that was 5/1000 smaller than their piston bore size before
