swagelok fittings on slp ls6 manifold ?'s
Hi all, some help regarding the EGR fittings on an LS6 manifold. Is the brass fitting only threaded into the manifold? or is there a nut that threads from the bottom of the swagelok fitting from inside the tb?
Bought a used SLP ls6 manifold but previous owner plugged the egr hole with epoxy and doesn't have the swagelok fittings anymore. I'm planning to buy the fittings and drill out the epoxy cuz I want the egr. Do I need to thread the hole as well? Any info greatly appreciated
