M6-->4L80e Need those part numbers
Old 05-30-2013, 10:00 PM
PaulC's Avatar
Smile M6-->4L80e Need those part numbers
Picked up a 4L80e and need some guidance.
19257940 Flywheel bolts
19260102 Flywheel
12563532 Flywheel Spacer
TD34L80FM36 Lokar Dipstick
This harness? or another alternative?
http://www.speartech.com/product_p/4l80eaddon.htm
Do I need to change my slip yolk?
Still need a4 pedals, I have hptuners.
What's a decent (cheap) shifter?
Also, I'm assuming this harness that's currently on the transmission is shot. Perhaps i'm wrong and its salvageable.
Old 05-30-2013, 11:23 PM
zgp
zgp's Avatar
2004 transmission. What type of transmission controller are you using?
http://www.powertraincontrolsolutions.com/ has numerous options for controllers and harnesses
Old 05-31-2013, 09:57 AM
PaulC's Avatar
I have hptuners, so I was going to have my PCM reflashed as a 2500 truck. My next question is should I scrap the used harness that's on the tranny now, or just buy a new one and not risk the old one missing wires?
Old 05-31-2013, 05:57 PM
PaulC's Avatar
If you look at my last picture with my torque converter, if I get a new TCI flywheel will I still need the flywheel spacer?
Old 06-03-2013, 09:35 PM
PaulC's Avatar
Got my harnesses taped up.
Pic 2 - Front VSS....Goes to pin 22 + 23?
Anyone have a diagram or a link to where the rest of the harness gets pinned to?
Rear VSS
Thank you for any insight.
Quick Reply: M6-->4L80e Need those part numbers
