Cost to go through my th400
Took my th400 to a trans shop and it needs the following...
All new bushings, seals, lower planets and sun gear, clutches and steels....
What would you think it should cost to go thought it.. I got a quote for $700 does that resonable?
Already has trans brake upgraded 4l80e drum etc...
Thanks
Thanks
i got quoted $350 just in labor to go thru a 4l80 to make sure everything was good and if anything was bad i would just need to pay for whatever part needed to be replaced.
so if you take that $350 - $700 = $350 in parts (in your case)
