Fuel Injectors 42lb Delphi 01D030B $250 Shipped
Category: Engine - Intake/Fuel
Price: $250
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): KS
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
Set of eight (8) - Delphi / Lucas
42 lb / hr. '009' Disc Injectors
Part Number Delphi 01D030B (Lucas old 5208009, Lucas New 621031)
Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Additional Information:
Top feed disc injectors use a small disc with six holes around its circumference. The disc rests on a short chimney that surrounds a metering hole. As the disc is raised off the chimney by magnetic force, fuel flows through the holes in the disc, over the walls of the chimney, and out the metering hole to form a full, finely atomized cone.
Performance advantages over pintle injectors (i.e. Ford / Bosch & Accel types) as listed by Delphi:
• The flat mating surface ensures that no excess fuel is present to evaporate and therefore, no deposits or clogging can occur.
• Compatible with alternative fuels (i.e. Methanol)
• Longer service life
• High-speed disc action allows wider dynamic flow range for improved idling
• Quieter operation
• Revolutionary disc design resists build up deposits which can affect fuel flow.
• No Fuel leakage for quicker starts
