Brand new door pin and roller, but roller isnt rolling. Any tips?
Old 06-06-2013, 12:22 PM
moderate Z28's Avatar
Default Brand new door pin and roller, but roller isnt rolling. Any tips?
Installed a brand new door pin and roller while the door was off getting painted. About 3 months later it finally got painted and put on the car and the roller isn't rolling. This will cause it to wear a groove in it fast which is the whole reason I had to replace it all. It had a HUGE groove dug into it.
What should I do to get this thing rolling? Soak it in PB blaster? Drill a tiny hole in the roller itself and lube the inside that way? Any other tricks? Thanks.
Old 06-06-2013, 03:09 PM
nitroheadz28's Avatar
Crap.. I just bought a spare hinge + roller and bushing to fix this, bad news .
Hopefully you figure it out, make sure you update the thread if/ when you do. Maybe just grease the crap out of it? I was planning on using the same grease you use for poly suspension, high pressure stuff.
Old 06-06-2013, 03:37 PM
Will do. I will probably try the simplest first, which will be greasing/lubeing it and waiting. I was thinking of having someone open the door back and forth while I tap on the roller with a hammer. The fenders are off getting painted so I have lots of room.
Old 06-13-2013, 08:00 PM
Did you get your roller working smoothly? I just cut my old one out, still working on getting that damn pin out . How'd you do yours, did you heat it up and pound at it?
Quick Reply: Brand new door pin and roller, but roller isnt rolling. Any tips?
