LS3 intake and nitrous plate throttle cable problems???
Old 06-07-2013, 09:58 AM
streetz28's Avatar
Default LS3 intake and nitrous plate throttle cable problems???
im running a ls3 intake and a 90mm nitrous outlet plate inmy 99 z28 and was running a bracket off the intake bolts but it was causing the intake not to seal off on number 2. What other options for a bracket do i have???
Old 07-23-2013, 10:55 PM
MertezWS6's Avatar
Sorry I don't have an answer yet but im also in the hunt for a bracket on my LS3 intake with 92mm throttle body. Called WS6store today and they have a couple options-#1 the SLP bracket that bolts to the intake using intake bolts (which you don't want nor do I) #2 is bye there Nick Williams TB and they have a bracket that bolts to that. But I like most dont need to spend $400 on a TB. So Ill keep looking and hopefully someone will chime in on what they have done.
Old 07-26-2013, 01:58 PM
No Juice's Avatar
Been here done that.
SDPC has one, bolts to the back of the TB, but hits the #2 runner.
So what I have determined is that you need to make one or modify the SDPC one
Old 03-28-2014, 04:37 PM
slvrbltgt's Avatar
It won't work with the bracket that bolts to back of tb if ur running a plate I'm also searching for one
Quick Reply: LS3 intake and nitrous plate throttle cable problems???
