A/C fan and relay question
Old 06-08-2013, 09:55 PM
jlay's Avatar
Default A/C fan and relay question
I couldn't find my answer directly so I will ask. Can I hook my vintage air trinary switch wire and my wire from the PCM for the fans to the same terminal on the fan relay. The relay is for my second fan both are negative triggers. I wanted it to be the fan for my a/c but also have it functional if the temp gets too high. I didn't think it would be a problem but just wanted to be sure before I finished it up. Thanks in advance!
Old 06-09-2013, 04:17 AM
garys 68's Avatar
Yep, that's how mine is wired.
Old 06-10-2013, 08:11 AM
jlay's Avatar
I didn't think there would be a problem but just wanted to see if anyone else had it wired this way also.
Quick Reply: A/C fan and relay question
